AGR Rock Ram
Transporter
Anyone ran these on a F-350.Does the new steering box ect seem to be any better than stock.I an trying to get some of the play out of my steering that i seem to have developed or always had.Running 8 inch Rize lift and 37's.Might try adjusting steering box and making sure pitman arm nut isnt loosening off again too.
I have a AGR box on my Ram 2500 and am not impressed. The first day I put it on it had a VERY back leak from a seal, so sent it back and got sent another one, that had just as much play in it as the original one. I since have tightened the adjustment screw and called it good. On other forums guys have had similar experiences and have suggested buying one from Napa Auto parts as they are half the cost and work just as well if not a bit better.
Heard you have to make sure you use the provided seal on the high pressure fitting on the back.Did you have the ram assisted steering or just the steering box.
I have the gear box only, and far as I know it did not come with any high pressure seals. Wouldn’t have mattered with the seal that went as it is was a manufacturing flaw as stated by them after the review. It does however have a tighter ratio, so less turns of the steering wheel to accomplish a full turning radius.
