I just got my order of engine parts to rebuild the top end on my 06 Summit X 800. I ordered a Widerosa gasket set for the top end thinking it would come with choices of base gasket thickness. I was wrong. It only come with one and it is not marked as to what the thickness is. I called the retailer and he told me that is a .025" thickness gasket and the is the same as the BRP gasket that I removed which has 7 pin holes in it between the jugs. When I do the convertion from standard to metric it only comes out to .635mm. Would this be the right gasket or would it be considered a .6 rather than a .7? Am I going to be alright to install it or will is throw things off.
