You have placed your EGT sensors too close to the exhaust ports if this is the case.
Afr for turbo's and egts for NA sleds.
Mounting location on both is important. What kit is it, year version etc...
the 800 is a lot different than the 1000 also, the 800 can withstand a lot higher temps, the 1000 can't and will go down.
What are your egt's reading versus your A/f guage? I have both also. On a long pull I hit 1300-1350 but my AFR sits at 11.8-11.9. If I add fuel to bring down the EGT's, the sled is boggy.
Hey Sno Junkie,
Did some more tuning this past weekend. We are now seeing 12.4-12.5 AFR and right around 1200F on the EGT's, this is on 91 pump at 7 psi.
Last time out saw 13.0 and 1300-1330. I like it when I get the results I expect when firing the fuel at it on the top end. Also had a lean spot on the trail - adding 5-6 points to the psiL LO number solved that right away.
