aerocharger M7 turbo?
Went riding today for the first time this year with my TM7 after I just rebuilt the motor and 53 Aerocharger.The problem im having is it seem way to rich on the bottomend the sled hardly moves tell it clears up then it rips.I played all day with the pure logic box but nothing play with the fuel presure as well. another problem is I have to have all my lights at 1 or the sled just boggs and runs like **** last year ran them all at 1 and the sled worked awesome tell I spun a ring and took out the turbo.any help would be awesome. o ya some one said to take shims out of the fuel regulator to lean it out then turn my numbers up.fuel presure shoud be at 38 right also running strait av fuel as well last year mixed half av half 91 could that be the problem thanks
If ran good with 91 I would try that first, then try dropping the fuel pressure next.and is your primary in good shape?
I run my fuel press at 35-32psi running at idle red 1or2 yellow 2 red blue 7 blue green 5-6 the fuel pressure should be set at idle till the sled is crisp spark plug gap set at 18 hope this helps this is for 10lbs of boost
