Adjusting belt height 07 800r at the secondary.
Tuesday
Is it me or when I loosen those 3 bolts on the secondary and spin the adjustment dial from 3-6 I dont see the ride height of belt change alot? Looks like I have 2 belts sitting quit low when at the 6 mark. Guess they are worn out?
Yes after changing belts and settings I run the sled so that it can reset.
Later
Belt height
I found even with new 0166 belts they were to skinny and had to start with adjuster at 4-6, switched to a 0377 and now I am down at 1-2 on the adjuster plus I have 350 miles on the 377 and it still looks like new. This is on an 07 800r.
secondary adjustment
You guys need to pull one of the 2 shims from between the secondary sheaves out. This will allow you to start at position 1 with the proper belt height even with the stock 166 belt.
