Adding riser to Telescoping riser
When I demo'd the '10 M8 it felt like the telescoping riser needed about 1 more inch to make it perfect for me. Anyone heard if you can put a riser on that new setup?
Yup
I broke my bars in half and wanted fatty's so I got a Rox 2" 7/8-1 1/8 riser adapter. Works good and allows a little forward movement as well. Feels alot nicer than my buddy M8 with just the tele riser.
Check it.
SPDFREEK
Thanks for posting, Looks good! Did you have any issues with cable length? Do you think the Rox 3 1/2 inch riser would have worked?
I'm trying to get my bars about 1.5 to 2 inches forward and about 2 inches higher. What do you think? is it doable?
I've looked at the amp riser block but It's not quite what I'm looking for.
think so.
Should work with 3 1/2. And as far as getting the bars further forward...with the Rox they will roll forward. That is why I liked them. Also allows for a little more give...the riser will roll forward if you don't tighten them to tight, before the post bends on those hard hits. Good idea for all if you ask me.
Hope this helps.
SPDFREEK
Thanks alot!!! I've been thinking about going this way for a while but didn't want to pull the trigger till I got a look at someone elses set-up.
Thanks again, Reese
