Acidentally ran diesel through a Nitro FX!! Help
A
AKholicsAnonymous
New member
so lets say (hypothetically) someone accidentally put diesel fuel in a Nitro with less than 400mi and ran it until, surprise surprise, it died. tank was approx. 1/4 full (with premium) prior to being filled with the dies.
what kind of problems could this create? worst case? could the higher compression have bent the rods, blew the rings, etc? thinking of just draining the tank and lines, replacing the filter/plugs, oil change for good measure and trying to fire it up. but i figured i'd check with those who are actually knowledgable on the subject before i potentially ruined a basically brand new sled. any help is appreciated! thanks
Drain it all and get fresh gas in and try and start it. Its when you put gas in a diesel machine you have issues....should be fine I would think.
Nope, can't even fix it, the whole sled is junk now
Even wrecks the suspension and track
Give ya $300 for the scrap :D
I once filled my dad's rzr with diesel, siphoned it out and filled it with gas, still running fine and that was probably 1000 miles ago. Not a sled but both 4 strokes, you shouldnt have a problem. I also have filled up my dad's diesel truck with gas :doh: felt stupid after that one.
If it was me I would drain out fuel, fill tank with new gas, replace the spark plugs, start it and ride. good luck but you should be fine
a buddy of mine accidently put some deisel in his nytro [only about 1 1/2 gallons] then topped her up with gas and it ran he burnt the whole tank out of it and never skipped a beat
I have seen this a few times...drain as much as you can refill with fresh gas, and change the sparkplugs...nothing else needed...it wont hurt the motor or the fuel system...might run a touchy funky for the first tank..
well apparently i was making much ado about nothing. just like y'all said....emptied it out, new filter and plugs...started right up. smoked pretty good for a while and now back to normal. thanks! :-D
Your dad must be a patient man.
Watched a guy put 6 gal diesel in his polaris, he freaked out, asked what he should do, I siphoned it out, and dumped it in my apex. Free gas, nothing better.
