H
Hairy Mark
while doing a pull this yesterday i burned my m8 down. the culprit, the o ring that seals the injector to the throttle body. it was pushed out causing the fuel to go out instead of into the injector. was fixed by twisting the fuel rail in the direction toward the rear of the sled causing more pressure holding the injector into the throttle bodiy. please check this so it doesn't happen to you.
