AC 800 bottom end with extras!!!
catmann
New member
I have an 2002 "large crank" zr 800 bottom end complete with engine mounting brackets, stator, flywheel, and recoil. Same exact bottom end as the 900. Ready for your big bore!
SOLD! Thanks Ron.
Engine brackets to mount this motor in any zr2 or zr3 chassis. Perfect for those engine swaps to the big block motors. $40
02 zr 800 carb stock pipe and silencer $40
D&D 02 zr800 carb, stock pipe clutch kit. This made this pull very very hard. 81 gram weights! $100
Also, available used primary clutch for same motor $100 (2200 miles)
Found a few more things....
Sno*tek torque link for 800 and 900. Doesn't increase vibes at all, but does hold it in place. Get the power to the ground. Like new! $50
15X121" closed window grass track. Double back woodys studs. No pull throughs. two tweaked studs. very very nice $250
94-95 zr700 Aaen ported top end. Plating is tired, but is not scored. matching cut heads, which are perfect. These cylinders and pipes went 121 mph in 1000'. Twin aaen pipes included, but missing flanges. $150 for everything. Would prefer delivery at hayday only on these.
Yamaha Banshee Cut Toomey T3 pipes. Ceramic coated. These are crazy sleeper drag pipes. 11,000+ rpms. They fit the j-arm bikes only. Pipes only no silencers $125
**I can bring everything with me to Haydays if you are interested, or shipping is available. Paypal accepted on any or all items.**
Best way to contact is (920)-840-2042
Hi are these cylinders trail ported or race ported and are the heads cut for pump gas ? I am wondering if these pipes will fit my 2000 zr 700 ? ARE YOU ROCK SOLID ON YOUR PRICE ?
