Since it seemed a number of guys were struggling to inflate their TSS units using the supplied pump we wanted to try and save some people a bit of frustration and lots of endless pumping.
Tips and Tricks
Happy shredding, hope we helped save a few people some headaches.
IAP staff.
Tips and Tricks
- Make sure the shock pump is completely threaded down on the schrader valve.
- When starting with a deflated TSS, ensure all the weight has been removed from the shock by putting a stand or a jack under the bike. This makes filling far easier
- As pressures increase you MUST push the pump all the way to bottom, you can pump it back and forth on the top 90% of the stroke and will never create pressure. Make sure you are getting full travel and bottom the arm out every stroke.
- If pump is properly seated and you are using the full travel, going from 250-300psi for example, should only take 20 pumps maximum.
IAP staff.
