T
thedude306
"It's been a show", as my wife would say! The suspension geometry changed by moving the track on the driver ahead and it threw everything off. Had to redo the rails and move the top idler wheels. Also cut and moved the bulk head in towards the engine, but then it hit the valve cover. So messed with that for a day to get it just right.
My advice, sell, sell, SELLL and buy a 200 bahahahah
Bulk head cut and bent it. Had to weld it back up solid to keep the snow out.
here it was with the track rubbing
It's hard to tell from this picture but the idler wheels are move WAY back and down. They where origanally on the shaft that the top of the coil over is attached to. I am going to try and relocate the top of that coil over to the shaft with the wheels on it. It will work WAY better angled the other way.
We've only had it down the alley so far and I think it's going to work great. Geared back up to 2.3:1 (from 2:1) and that should give us 30mph Has better low end torque as the 5 tooth driver didn't seem to pull much power from the engine?? And it's been dang cold here. -30 this morning and that's the warmest it's been in weeks. I've been sledding but the kids can't handle it. The new Cold Guaurds, hooks and Maxx hand warmers are going to help though And I bought a proper Fly 5" riser.
And then of course I was having carb issues. Pulled the engine out 5 times yesterday and cleaned the carb 5 times. Fifth time was the charm. Idle circuit had something in it. We don't run an air filters and that circuit has a port on it that draws air. I'm sure we got a piece of chaff or canola stubble in it! Idles sweet again with 3000 rpm clutch engagement. Spins the track when you pin it. Replaced the coil as well with an OEM honda coil. We got RPMs! No power up that high but pulls good to 6500 RPM under load.
