A/F numbers help please!
tt m1000
My supercharged nytro a/F won't change no matter if I add fuel or take fuel or on or off the throttle it just stays at 14.6 is my sensor bad if so shouldn't be - - - - please help heading to cooke this weekend
Sent from my DROID BIONIC using Tapatalk 2
Bad sensor!
Mine did the same thing and I was told to change the sensor out.
It Worked!
Mine too except mine stayed at about 13.5 when riding. 14.7 sitting there idling. New sensor and see all sorts of numbers now.
Thanks I will buy a new one tomorrow
Well rode with the new sensor and now at full throttle it goes to like 16 so checked the gems controller and my boost fuel is maxed out.... Am I running my injectors maxed out?
How much boost are you running? What elevation are you running at? There are several settings that will impact the numbers.
I noticed that sometimes when i start from cold my GEMS don't put out any extra fuel and i have 15-16 afr @ wot, after i shut my engine down and restart it works just fine with 12 afr @ wot.
Strange thing is that all lamps ect are active on the gems but it does not add any fuel.... if you dont have a afr gauge and keep an eye on it things might get expensive :face-icon-small-sho
Iam running 16 lbs at 9-10000ft with straight 112octane
