A different view Video
X2 on that. Nice work Chad. You're using Final Cut?
Makes me want 2 cams.
Did you get that bumper to work?
I am actually using a program called LioLo Scope on a PC. My old version of Final cut cant handle these files.
Yes I put some JB Wled on it that night and put it on my sled this morning. It seems like it is going to hold so I will go out and test it tomorrow. I am going to place the camera on the front of the sled this time so hopefully sometime next week I will have some footage up from that. Thanks again for the bumper. I owe you.
NIce.....Got a high rear mount I need to test out. I was able to get rid of the vibration by anchoring at another point as well.
Good change of view from the bumper, like the picture in picture, my suggestion would be while editing to alternate PIP from bumper mount to helmet cam view periodically, mix it up a little by adding the front view as well, nice work, you've just raised the bar for everybody else.
Front view will be up soon. Just got to edit it. Snow conditions sucked yesterday, but I still managed to find a little hill to play on and get some cool shots. I will get a picture of the set up i am using soon.
Here is a picture of the mount I am using. It is made by Manofrotto. It came with a floor mount as it is intended to be use for holding lights for photography but I usually buy and use stuff in a way that was never intended to be used. It has worked really good. There is some vibration that I need to get worked out and I will be testing a few options next ride but it works really well.
I got mine on amazon.
http://www.amazon.com/Manfrotto-Magic-Backlite-Stand-Super/dp/B000J4GQVE/ref=pd_rhf_p_t_1
If you use the Contour you need either the waterproof case because it has the screw in the bottom for this mount or you need to get the Contour Universal mount adaptor.
http://www.amazon.com/Contour-3100-Universal-Mount-Adaptor/dp/B002H9XSWO/ref=pd_rhf_p_t_2
