A arms
I broke top and bottom a arms on the left side today. I got an 04 king cat 900. I started taking it apart tonight and i dont know how to get the bolts off. I can get the ones off that are hooked to the ski side but not the ones hooked to the tub. any help would be great.
Upper A arm you need to pull the rubber tie rod boot, nut inside. The bottom you need to take out the screws along the belly pan front. It is up inside. I don't know if removing the one side screws will allow enough room to get in there?
Mike
