995cc Genesis....SOLD
I
itsallgood
Ported (T8RZ-09) PSI Genesis 995cc / New top end & seals two seasons ago.
Includes
SLP Twin pipes w/ large PSI ceramic coated silencers
rifle bored Mikuni rack carbs (41.5mm).
PSI's updated thicker PTO end
PSI high volume oil pump / no mix required
PSI billet thermostat
Ignition
Clutch
Runs great as is with conservative timing, jetting & compression. This is a true PSI Genesis motor (PSI cases) not a PSI big bore kit on a Polaris / Cat bottom end.
PSI charges $7k for this motor not including the carbs, reeds, ignition, oil pump, clutch or billet thermostat.
http://www.psipowerinc.com/346910.htm
$2800.00
The new crank & this kit was installed in 2003. Estimated mileage is 1400. I've riden with the original owner over the last couple seasons I can say this motor is pampered.
Ya sold it, eh? Good job.
Someone got a motor with Turbotater's porting.....they got something good.
