99 600 jetting
You are sort of in the middle of two charts so I will give both. Operating rpm should be 8000 +or-200
Clutching specs
0-3000 feet
Dark Blue primary spring,10-58 weights, secondary spring Silver/Blue R-8 helix #2 location.
3-6000 feet
as above only with 10-56 weights.
Jetting specs for all elevations are the same except for air screw adjustment because the sled came with ACCS for altitude compensation.
0-3000 feet
Below -20F 195 mains, air screw 2 turns
-20 to +10F 190 mains, AS 2 turns
+10 to +40F 185 mains, AS 2 turns
above +40F 180 mains, AS 2 turns
3-6000 feet
Below -20F 195 mains, AS 1.5 turns
-20 to +10F 190 mains, AS 1.5 turns
+10 to +40F 185 mains, AS 1.5 turns
above +40F 180 mains, AS1.5 turns
Pilot jet 50
