98 mountain srx 700 jetting
Hey never posted here before, done alot of reading and very knowledgable guys right on
Got a question about jetting I go out to the mountains in BC and am trying to get set up perfect, last run out spark plugs gave me some issues not firing actually just one did. My current jets are
Main 1&2 - 141.3 Main cyl 3 143.8 pilots are 47.5, Does anyone have a chart that tells you alitude comparison chart temperature and what not for elevation change? Sled has V force 3 reeds and mbrp can engine wise thats it I really dont have a clue what I should jet to my base elevation is 850M and in the mountains the rise can get up to 1900M I am looking for the exact jets I need to make this work. I have an ataac altitude compensator on the way and for those things to work good sled is suppose to be jetted perfectly. Any help would be greatly appreciated thank you very much
chart
Start with this- hope it helps
http://www.zenitram-inc.com/Manuals/MM700TU2.jpg
that has to be a different sled it says mountain max I dont think they are the same as mountain srx w/ triple pipes those numbers are way off even from stock do you know where I can find one on my exact sled or atleast srx triple? Thanks
SRX
Gerry, I ran 130 mains, 57.5 Pilots, #2 clip and fuel screw 2 turns out at 10k ft. Mine had Bender silencer. Ran flawless. Good luck.
