ok so 97 ultra bottom end crank was trued and welded by union bay before they went out of wa, case ported if that means anything to anyone...
bottom end has maybe a thousand miles on it and the top end has roughly three thousand miles on it
vforce 3 reads less then a thousand miles on them, as well as prok filters and outerwear
oil injection system has been removed premix(40-1) 3.2 ounces per gallon is what i was mixxing the fuel at... it was a couple few years back so my numbers could be off alittle bit
xcr coil mounts, much cleaner then the stock ultra setup, includes everything to make it run,carbs,coils,primary clutch,computer,wiring,custom plug wires i even have some ceramic coated slp high rpm pipes i will include or sell seperately
i am sure i am missing a few things
900 OBO i have been out of the sledding sean for a few years so best offer will take the engine and pipes
located in kenmore/bothell area
425 6053574
TIA
James
425 6053574
TIA
James
