97 Summit sc10 parts please
Hello everyone have a 97 Summit w/670x motor and I`m looking for some parts for the sc10 rear skid, I took the skid out to clean up and check out the condition of the bearings and stuff and found that the center of the front arm was crack at the weld next to the center shock mount I can reweld and fix that pretty easy but need the aluminum center rod that goes in the upper tube, the one between the bushings of where the front mount bolts if that explains it good enough. Also could use the top piece of the rear arm it has a groove worn in it where the upper wheels slide on.
Also could use a pair of rails possibly, there bent ahead of the front arm mount, can possibly straighten on shop press if none are available. Yes sound pretty worn out I know but unless some one has a sc10 136 skid or a sc102 skid pretty cheap pretty sure I can fix
