I am finally finishing up the 97 MM700 for my son.
I added a 4" pivoting bar riser so I had to change the throttle cable and oil pump cable to the 2003 MM700 cables.
The throttle cable was no problem, the oil pump cable was not fun. I ended up prying a screw driver against the oil pump arm to keep it in the full oil postion so I could see and reach the arm to be able to swap the cables.
I FINALLY got the cable changed out and noticed a huge puddle of oil on the floor. I figured it was chain case oil since I had just got the gears for the machine and put the chain case together.
But no, it was injector oil. It drained the injector oil tank dry. So I thought, ok it drained all the oil while I had the oil pump arm in the up (full oil) positon? So I added a little more oil today and a fresh container under the sled and I'll be dipped if all the oil didn't drain again into the fresh drip pan again.
The arm seems to be returning to the no oil position (the cable has no tension on it) so I can't figure out why all the oil is draining from the injector oil tank (unless I some how knocked the oil line off?). The oil pump is mostly under the motor mount so I really can't see much under there even with a mirror. I hate to pull the engine to fix this issue but, to see what is going on you'd almost have to do so.
If any of you guys have been here and know the easy fix please let me know. I'm getting tired of seeing all the expensive injector oil draining into a drip pan.
Thanks in advance for any advice.
Frosty
Frosty
