1997 JEEP WRANGLER – 4.0 L 6 CYLINDER / 5 SPEED MANUAL TRANSMISSION WITH 104,000 MILES.
DRIVETRAIN:
-Bored Throttle Body
-M.O.R.E. Engine Mounts
-Flow master Exhaust
-Removed Cat
-02 Simulator (tricks computer into thinking the Cat is still there)
-Centerforce II Clutch
-Rebuilt AX -15 transmission
-Hurst Short-Throw Shift Kit
-NP231 Transfer Case Overhauled when the SYE kit was installed
-Advance Adapters Slip Yoke Eliminator Kit
-Tom Woods CV Drive Shaft
-Rear Disc Breaks
-Stainless Steel Extended Brake Lines
AXLES:
Rear – Ford 8.8, 31 Spline axle shafts, 4.88 Gears, ARB Air Lockers, DTS Cover. Axle came from late model Ford Explorer and was custom built by Drive Train Specialists in Warren Mi.
Front – Dana 30, 4.88 Gears, ARB Air Lockers
SUSPENSION AND TIRES:
-Rubicon Express 5.5” Extreme Duty Long Arm Lift
-1.5 inch Body Lift
-Rubicon Express Adjustable Front Track Bar
-Rubicon Express Adjustable Rear Track Bar
-Tera Flex Sway Bar Disconnects
-Ranch RS 9000 Adjustable Shocks
-35” x12.5x15” Goodyear MT/R tires mounted on 15x10, 3.5” -Backspaced Eagle Alloy Wheels. Brand New Spare.
BODY AND ACCESSORIES:
-Poison Spider Full Rock Cage modified to be able to use rear seat!
-Poison Spider Rocker Knockers
-Bushwacker Pocket Style Fender Flares
-Warn Rock Crawler Front Bumper
-Hella Lights
-Kilby Steering Box Skid Protector
-New Dodge Durango Steering Box – MUCH stronger than stock.
-Jeeperman rear Bumper with Swing Away Tire Carrier.
-Hi - Lift Jack
-Corbeau Reclining Racing Seats
-4 point Corbeau Harnesses
-Husky floor mats
-Optima Yellow Battery
-ARB Air Compressor
-Warn HS9500i Winch, mounting plate and roller fairlead
I am posting this for a good friend of mine. Please DO NOT PM me on this!!!!
You can contact Mike at:
616-292-3720
OR
heyellis1@yahoo.com
He is asking $11,500 obo.
DRIVETRAIN:
-Removed Cat
-Rear Disc Breaks
AXLES:
-1.5 inch Body Lift
-Hella Lights
-Hi - Lift Jack
-Husky floor mats
-ARB Air Compressor
616-292-3720
OR
heyellis1@yahoo.com
