Cylinder head:8mm 17-20 ft. Lbs.
:10 mm 24-26 ft. Lbs.
Cylinder base nuts:24-28 ft. Lbs.
Crank case:8mm 17-18 ft. Lbs.
:10mm 23-25 ft. Lbs.
On the water manifold bolts i would do 5-8 ft.lbs. If i were torquing them, but i never have on any of my builds, i just go by feel and expirience.
Advice: use plenty of oil during asembly. Oil the ring lands after installing the rings, put plenty of oil in the drip holes to the main bearings on the crank, as well as the con-rod bearings and wrist pin bearings. Make sure to check your ring end-gap, pistons should have come with a spec for this. If you are still running oil injection, premix the first 2-3 tankfulls with a pint of oil in the fuel (about 1 pint to 10 gallons) if you are not running oil injection, run the first 2-3 tankfulls at a premix ratio of about 20:1. Heat cycle the engine at least 2-3 times before you rev the engine at all: start and idle to operating temp and then shut down untill fully cooled down and repeat. This takes a while, but will help insure best performance and longevity of your fresh topend.
