I purchased a older Summit - and have been set on rebuilding it... the monumental task is almost done...
Before I took it apart I did notice it was running really rich - the plugs were oil fouled.. and I found some fuel in the exhaust.. I did notice that some of the HAC lines were in rough shape... In the whole rebuild process I decided to replace every line there was.. and have cleaned the carbs and reset the carbs to factory settings - 1 turn out on the Pilot screw and readjusted to idle to specs..
I was reading here on the site about removing the HAC all together.. ( I dont ride in the mountains - just from 300 - 2000ft..)
Currently at stock there are two 380 main jets and two 480 P-0 needle jet.
Does anyone have a recommended replacement jetting? or should I just leave it all alone?
If I were to remove it all There are two ports on carbs - do I just plug them up? and with what?
I did a compression test - and it was 120PSI a side.. and took the top of the engine.. it all looked good..
Thanks
Thanks
