94 summit 583 Parting. Electrical issue, motor should be fine, turns over fine, good compression. Carbs just cleaned. ALL PRICES OBO! Located in Seattle WA
Hood, no cracks, perfect shape, including gauge cluster $80
Windshield perfect $40
Ski's $20, need new wear bars
Front suspension, one coilover looks newer than the other $30
Control arms, good shape, not bent. $40 for both
Control arms, two upper, one lower, $15 for all
Ignition Switch, with key $20
Engine and carbs, good compression, carbs just cleaned. appears to be bad stator. $200
Stock pipe and Can $20
Front bumper, all metal one that wraps all the way around. $15
Steering linkages, not bent, rod ends tight. $20
Gas tank $15
Gas tank cover/shroud $15
Drive belts, Both Bombardier, one new, one light use. $40 for both
Belt cover, incl extra plugs! $5
Secondary, a little corrosion from sitting, scotch brite should take it right off $50
Belly pan, old crack that has plate riveted over it. $5
Foot rests, incl fuel shut offs. $5
Anything else, just ask. Im keeping the tunnel, track and skid. All prices OBO!!
![15173823048_8e3caabd34_c.jpg](https://farm4.staticflickr.com/3885/15173823048_8e3caabd34_c.jpg)
![15173822688_de02bceed5_c.jpg](https://farm4.staticflickr.com/3931/15173822688_de02bceed5_c.jpg)
![15491474122_be5042ae41_c.jpg](https://farm3.staticflickr.com/2948/15491474122_be5042ae41_c.jpg)
![15304917959_7e4cebf9c6_c.jpg](https://farm3.staticflickr.com/2947/15304917959_7e4cebf9c6_c.jpg)
![15305173488_f37881cfba_c.jpg](https://farm6.staticflickr.com/5600/15305173488_f37881cfba_c.jpg)
![15305126860_e1acfa536d_c.jpg](https://farm4.staticflickr.com/3955/15305126860_e1acfa536d_c.jpg)
![15305259417_8d499376fe_c.jpg](https://farm3.staticflickr.com/2949/15305259417_8d499376fe_c.jpg)
![15305258717_b6f3242fb6_c.jpg](https://farm4.staticflickr.com/3931/15305258717_b6f3242fb6_c.jpg)
![15305173908_84ae58a456_c.jpg](https://farm6.staticflickr.com/5613/15305173908_84ae58a456_c.jpg)
![15491826795_bff45d82bd_c.jpg](https://farm4.staticflickr.com/3952/15491826795_bff45d82bd_c.jpg)
![15178081670_0600b2f26f_c.jpg](https://farm4.staticflickr.com/3893/15178081670_0600b2f26f_c.jpg)
![15468702076_ff54251ed3_c.jpg](https://farm6.staticflickr.com/5610/15468702076_ff54251ed3_c.jpg)
Gas tank $15
![15305256597_187bb9355a_c.jpg](https://farm4.staticflickr.com/3949/15305256597_187bb9355a_c.jpg)
![15305258197_f318ea941f_c.jpg](https://farm4.staticflickr.com/3942/15305258197_f318ea941f_c.jpg)
![15468699776_284a16b97a_n.jpg](https://farm6.staticflickr.com/5600/15468699776_284a16b97a_n.jpg)
![15178248927_eedb088c21_c.jpg](https://farm4.staticflickr.com/3854/15178248927_eedb088c21_c.jpg)
![15178185578_9d63539a41_c.jpg](https://farm3.staticflickr.com/2950/15178185578_9d63539a41_c.jpg)
![15491472232_658277f9be_c.jpg](https://farm3.staticflickr.com/2950/15491472232_658277f9be_c.jpg)
