921cc stroker big bore polaris 800 cheeter
This is a 89mm bore, and 74mm stroke 800ves based motor. It has a re-stroked 700 crank (because they are stronger), with 139mm cr500 rods. We opted for a very strong bottom end. The cylinders are ves800 cylinders bore and ported @89mm for the 74mm stroke, power valves are fully functional. So all of the components are readily availible, and affordable. And from the outside, it looks stock :) . This motor has only break in time, and a couple of passes on the grass in front of the shop. It pulled 8400rpm with the oem 800 ves single pipe, and was amazingly responsive. This project is complete long after the 800ves market is old hat.
:( $3K and it's yours. 530-902-3052
