800R XP Carb Removal
remove the air box, loosen carb boot clamps. slide carbs back, lift high enough to remove drain plug to gain access to the jets.you might need to remove the fuel line.
air box
that box just slides out on a track away from the carb boots into it. loosen the hose thing that connects the front box to the back and the bottom will pull out towards you
