800BB Tune/Clutch
Just wondering what i should be running for a base tune in my sled, it is an F7(same as M7), with a D&D Big Bore 800 that uses the stock M8/CF8/F8 pistons, Aerocharger turbo around 6-7psi, with fuel pressure at 38psi. Will be in the altitude range in Okanogan mainly if it matters, don't know exact altitude but i'm assuming 4k-7k?
I am using an attitude industries control box. Right now i just guessed and will be starting with...
1.) (Mode 1 Green) 6.5 LED's
2.) (Mode 2 Yellow) 4.5 LED's
3.) (Mode 3 Red) 4 LED's
4.) (Mode 4 Green/Blue) 7 LED's
5.) (Mode 5 Yellow/Blue) No Secondary Injectors
6.) (Mode 6 Red/Blue) 4.5 LED's
I have no idea really what exactly the outputs will be on the fueling. But that's what i was going to start off with.
And for clutching, i'm curious to see what i should run for a secondary spring and helix, i have the torsion secondary.
For Springs i have(do not know the rates except on the AC Green Spring):
Navy Blue
Green (157)
Yellow
Purple
For Helix's I have:
60/54X
60/50
48/56
58/52
Any input on what combination of spring and helix AND why i should use them would be greatly appreciated.
Primary has:
76g STM adjustable weights with the tip being heavier.
Speedwerx Titanium with blue mark (165/310)
