on wahl bros web site the 7t are 6.55od and 8t are 7.50od , So I doubt it myself cuz the real limiting factor is the jack shaft. Not positive but when i did cooler mod to mine I forgot parts at pauls and the jack shaft was closest thing. Would be close though
If the cooler has been moved ahead on a Nytro to accommodate a 3" track with 7 tooth drivers; would there be enough room for 8 tooths with a 2.5" track?
Yes this will work 100% I know of two sleds running this set up with the cooler mod. You do gain track speed big time as well.
Longhorse, who's delete kit if ya don't mind?
If you ride the steep and deep, 8 tooths are hell on belts unless you gear back down. Been there and done that.
