7S replace std gage
What do you need to add 7s to a std gage matryx? In addition to the gage. Non e-start sled.
The guage, the install kit and a battery kit (if you want to be able to use it when engine is off). I don't have part numbers off hand but you dealer can provide. For the battery kit go with the CV customers lightweight kit. I did both my sleds last year and had no problems. Your looking at $1600 to $1700 all said and done.
Have a gage, need to know what other electric cables are needed.
V2V harness, V2V antenna, GPS antenna and main 7S harness. 1 or 2 of those come in the install kit (cant remember which) along with the 7s bezel. The others come with the display. A battery kit will just plug into the sleds main wiring harness and power the 7s through there.
Ok, thanks. That’s what I needed to know. There’s 2 antennas, one for gps and for vehicle to vehicle.
Anyone tried using a better gps antenna? Better reception on cloudy days.
Never needed anything with stronger gain. Road in all types of weather and gps always hooked up. That gps puck is a pretty common antenna and I've used the same thing in many different applications.
