A
AKdragon700
How often do you find yourself in high gears? For me, I would have to ride trails a good 5+ miles to riding. Will I not be able to keep up with sleds with only 5 gears?
You'll have them in the corners but they'll have you in the straights. It's a give and take. 60MPH should be plenty of speed... never been a problem for anyone I've rode with. I'm usually passing sleds on the side of the trail.
I wouldn't worry about 6th gear, what I would worry about is the spacing on bikes that have 6 gears to start with. They typically have a wider spacing between gears,and that makes it tricky to grab a gear higher. I wish my bike had the close ratio transmission.
I found that through gearing the kit really low I was able to use 4th for most hills. My top speed in 6th wasn't much higher than any MXer with a 5speed box.
I've changed my gearing now, and haven't had a variety of conditions to say if I've made the right move or not.
I'm on a 500 XC-W
What gearing are you running, i was thinking of doing that very thing or that very reason on that very bike.
