54 / 66 gears ....clutching?
Ok. did a search and nothing turned up. Im installing 54 / 66 gears in my 08 M1000 with a 162. Speedwerx pipe and y pipe with boondocker. Ive got the fuel dialed right in. My current gears are 57 / 63, I run normally 7000 feet. I weigh about 200 lbs with gear. What are you guys running for weights with these gears 54 /66`s. At the moment im running 80 gr. (factory weights) at 7000 feet and achieving 7500 rpm. Torsional secondary with straight 36.
Im thinking I need about 82 grams of weight or go up to about a straight 38 or 40.
Ya that sounds about right! I am running 56/64 with speedwerx exhaust and a ported motor and a head and I run 82 grams of weight with a 40/36 compression helix at about 7700 rpms! thats at 10,000ft
