433 Ramps...what set up are you using w/ these?
Skidooer
It seems a lot of people are liking the 433's. I like mine better but still don't have just the right setup.
What is your set up with these? Weight, Spring, Helix, Gearing?
433 ramps
Looks like you are in Idaho and probably ride between 8,000 and 10,000 ft i'm assuming? I ride the same area and use a 160/320 primary spring and 18.5 grams on 151 and 17 grams on 159. The secondary i use stock spring and 44/40 helix and it works awesome. I also gear down top to 19 tooth. Hope this helps.
Damn near exact set-up as we usually ride lower elevations. 4-8k. I use 1mm Oversize rollers btw. 19-47 gearing.
