All those oils don't meet yamaha's specification of api SG, jaso MA , almost all brands do make oils that meet the specification but none of the car motor oils do. I run Lucas motorcycle oil 0-40w.
O' contrare!
From the Amsoil website:AMSOIL Formula 4-Stroke® PowerSports Synthetic Motor Oil is recommended for four-stroke engines and transmissions on two- or four-stroke powered applications. It is an all climate/all season oil that replaces 0W-30, 0W-40, 5W-30, 10W-30 and 10W-40 oils for ATVs, UTVs, snowmobiles and other power sports equipment. Manufacturers include Polaris®, Honda®, Yamaha®, Ski-Doo®, Can-Am® (Bombardier®), Suzuki®, Kawasaki® and Arctic Cat®.
• API SL/CF, SJ, SH, SG
• JASO MA/MA2
• ISO-L-EMA2
AND:
Excellent For Transmissions
AMSOIL Formula 4-Stroke® PowerSports Oil is wet clutch compatible and contains no friction modifiers, making it ideal for both two- and four-stroke ATV transmissions. The friction modifier-free formulation is designed to prevent clutch slippage, delivering maximum torque and power to the wheels – a critical feature for towing or high-horsepower engines. AMSOIL AFF meets the frictional requirements of JASO MA/MA2.
And more info about the API ratings:
“S”- SERVICE CLASSIFICATIONS FOR GASOLINE ENGINES
SH- For 1994 Gasoline Engine Service
Classification SH was adopted in 1992 and recommended for gasoline engines in passenger cars and light trucks starting in 1993 model year. This category supercedes the performance requirements of API SG specification for 1989-1992 models, which is now obsolete. Applications that call for an API service classification SG can use the SH specification. The specification addresses issues with deposit control, oxidation, corrosion, rust and wear and replaces.
SJ- For 1997 Gasoline Engine Service
Classification SJ was adopted in 1996 and recommended for gasoline engines in passenger cars and light trucks starting in 1997 model year. Applications specifying API SH can use the newer API SJ service classification. Note that where applicable certain letters in the sequence will be skipped to prevent confusion with other standards. In this case, SI was skipped since industrial oils are currently rated according to SI classifications.
SL- For 2001 Gasoline Engine Service
Recommended for gasoline engines in passenger cars and light trucks starting in July 2001. SL oils are engineered to provide improved high temperature deposit control and lower oil consumption. Applications specifying API SJ can use the new API SL service classification. Note that some SL rated oils may also meet the latest ILSAC specification and/or qualify as energy conserving. SL is the latest specification.
SM- For 2004 and newer Gasoline Engine Service Automotive Engines (Current Spec)
This specification was introduced in Nov. 2004. SM oils are engineered to provide improved oxidation resistance, improved deposit and wear protection and improved low temperature performance. Note that some SM rated motor oils may also meet the current ILSAC specification.
