4" pivot riser on a ZX
I put a 6" riser on mine & had to get the extensions for both the brake & throttle. Make sure you realign your oil pump cable after you are finished. Otherwise............. KABOOOOOMMMM!!!!!:mad:
My 01' took an 8" riser no problem, don't know if lines changed in the years, though! My brake line was a little tight until I noticed that the banjo fitting on the caliper side went down then back up, so I loosed the banjo bolt and rotated it up, got me about another 3"!
Had a 6" block on my '01 X, no lengthening required. I do have roundslides, but it was a stock cable for those. And no oil pump. But the brake line made it, as well as the wiring. For the wiring I was still using, anyway (hand grip heaters and tach).
