I
itsallgood
Thinking of adding 4" exhaust to my Duramax to lower towing egts. Heard it doesn't make much of a difference @ elevation. tow between 6'-13k. Anyone have before & after results?
I have a 04.5 duramax. definately noticed a difference with the aftermarket exhaust and cat delete. noticed an even bigger egt diff with the diamond eye downpipe. more with the downpipe than the exhaust.
I would always high temp alert when towing with my edge chip, went to 4" exhaust and cured the problem. Never seen it high temp since.
If you are going to spend the money and time why wouldn't you do a 5" turbo back system?
International and Cummins say 1200 EGT (pre turbo) can be sustained with no limits. Mack says 1250.
The "guidelines" that many follow are:
1200 or under, no worries
1300 for no more than 1 minute out of 5
1400 for no more than 30 seconds every 5 minutes
1500+ no more than 10 seconds every 10 minutes
Me personally, if I see more than 1300, it is time to back out...
. I have seen duramax's run 9's and not blow much smoke
