I went with a 174 3", I used an Avid extended chain case with 8th drivers
Hey 4Z, didn't you run a 3" before and you thought it took all the fun out of it, hooked up to hard.
Don't rule out the peak 2.5. Buddy runs one on his Pro and it works. I'm a huge fan of PC track. ran one on Doo for last 4 years and love it. Would consider Peak aswell. Hooks hard on setup and floats well on pwder. He just put carls big bore in and says it works awesome with new track.
My .02
You should probably buy the Powerclaw and then report in detail your findings... Haha. I'd really like to know if it's worth the ~$900 to upgrade from stock.
Yup. But that was on a cat and it was the old style stiff-as-a-board paddle that weighed a ton #excavator #steel. The pals I ride with that have the new 3" (and owned the old style #excavator too) report it is much more firgiving design. You can "slip" around things without the #Velcro effect. However on the pro, smaller drivers are needed, which I don't want to do unless necessary. Or, the billet ca$e.
Starting to lean towards the 2.6 PC at this point.
