225 lb spring
T
TriumphoverU
What are you guys running for pre-load on the front 225lb spring. What is a good starting point? Are there any rules of thumb to go by when adjusting front spring pressure?
BTW I'm running a Fusion and not an RMK, but I believe that I would be in the same neighborhood as the RMK's. I weigh 225 w/o gear if that helps any.
Thanks in advance,
Dean
There's many variables but I started at 1/4" of preload and it was a noticeable difference from the stock spring. Your going to have to experiment
Set it where the old one came off , ride it and it will "settle" a little and if to stiff loosen a turn at a time as it's easier than tightening it out on a ride.
