22/47 gearing on 08 summit
Why do you think you can pull those gears? Pretty much everyone is running 19/20:49
that is gearing down 2 teeth on what the sled came With 23/45 what would you reccomed for elevation on a 146 summit + in the flatland boondocking 1200 feet
thanks
juggs
I'm not aware of a 47 tooth gear that fits the xp spline. If you have a 45/23 now, I would try a 22 top with the 104 chain or a 21 top with a 102 chain.
Here's a quick chart
106 27 45 1.67 128 204
106 26 45 1.73 123 197
104 25 45 1.80 118 189
104 24 45 1.88 113 182
104 23 45 1.96 109 174
104 22 45 2.05 104 166
102 21 45 2.14 99 159
102 20 45 2.25 95 151
102 19 45 2.37 90 144
102 18 45 2.50 85 136
juggs
a 22/47 is almost identical to a 21 /45 but will not have as sharp as bends in the chain , which is a plus and i will not have to buy a chain then
here are gears available from HPE
Ski-Doo Bottom Sprockets
13 WIDE
2" (50mm), 32 spline / Fits Fits Rev XP 2008
43 Tooth Sprocket
(Reference #813-472)
Retail $74.95
Your $51.97
43 TOOTH
1 In Stock
44 Tooth Sprocket
(Reference #813-473)
Retail $74.95
Your $51.97
44 TOOTH
3 In Stock
46 Tooth Sprocket
(Reference #813-474)
Retail $74.95
Your $51.97
46 TOOTH
7 In Stock
47 Tooth Sprocket
(Reference #813-475)
Retail $74.95
Your $51.97
47 TOOTH
7 In Stock
48 Tooth Sprocket
(Reference #813-476)
Retail $74.95
Your $51.97
48 TOOTH
13 In Stock
49 Tooth Sprocket
(Reference #813-477)
Retail $74.95
Your $51.97
49 TOOTH
15 In Stock
51 Tooth Sprocket
(Reference #813-478)
Retail $74.95
Your $53.50
51 TOOTH
1 In Stock
I learned something new today!!! I wouldn't trust the 51T in the stock chain case, the 49 is real close. As far as a 47/22 you should be ok with the stock 104 chain.
I havent seen anyone running a 51 tooth bottom. The sharp turn you are talking about with the smaller top gear doesnt matter as much as you would think. I have run the 19/45 combo with no problems. jmo
