21/22 driveshaft conversion
G
Jan 30, 2010
84
54
18
Just wondering if anyone knows the part number that is on the 21/22 driveshaft to install in a 23? I know the whole assembly part number is 504154023 but I have a shaft from a 21 and the number on the shaft is 504154059 and the machine it came from lists the 023 shaft. It is also longer on the gear side and would require a spacer behind my bottom sprocket. Any info would be appreciated. Thanks
C
caper11
2,064
2,184
Northern alberta
A 21 will fit the 21 to 23 bottom sprocket. You will need a new speed sensor oring for the 21 driveshaft. The 21-22 driveshaft is thicker on the ID and needs a thinner oring.
G
Jan 30, 2010
84
54
18
What I am seeing is the driveshaft is 1/4" or so linger on the splines and my 53 tooth hyvo gear will need a spacer behind it to line up to the top gear and keep it from rubbing the inner chain case
G
Jan 30, 2010
84
54
18
After more looking the bottom sprocket doesn't rub the inner chain case but either way i would need a spacer on between the gear and circlip. Looks like a 5mm spacer between the gear and circlip would be required. Is anyone else running into this?
C
caper11
2,064
2,184
Northern alberta
Are you sure it’s a 2021 driveshaft, 2021 and 2022 drive shafts have the same bottom sprocket.
A 2020 needs a 2020 sprocket because it has a shoulder on it to take up that space.
C
caper11
2,064
2,184
Northern alberta
It may of been installed in a 2021 but it sounds like a 2020, is it a NA sled, that my be the difference too, I’m unsure.
Regardless, it will need a 2020 bottom hyvo with a shoulder to take up that gap.
C
caper11
2,064
2,184
Northern alberta
I just put a solid shaft in my G5 and I ordered for a 2022.
I can’t help with the pn on the driveshaft until I get home be doo has been selling complete assembly’s for awhile. I wish there was a pn for just the bare shaft.
G
Jan 30, 2010
84
54
18
I guess I will just run the 2 piece with the TKI kit and my hyvo set up, I don't imagine I will have any issues with that set up.
Thanks for the help.
