2023 850 w/silber NO START
Hey guys, I have a 2023 850 RMK with a Silber turbo. Sled died on me yesterday on the mountain. Happened mid pull just like it ran out of gas. Pulled over at least 100 times. Checked obvious things like plugs, spark, disconnected fuel supply line and seems to have adequate pressure. Disconnected fuel return line and nothing coming out. Tried the diagnostic port disconnect trick and nothing. Where can I go next? Any help is appreciated. Thanks guys!
Did you check compression or your tether? When you pulled the plugs did they have spark and how did they look?
The plugs had spark but seemed weak. Without a compression tester the rope feels good on every compression stroke. Plugs were a nice golden brown. Wouldn’t fire with gas directly in cylinders either. If it sits a while it will burble on the first pull but die immediately.
I have 2022 NA 850 been sitting in the mountains for a week. Same symptoms as yours.
Packed up a fuel pump , no go. Tried different ecu , no go.
Next try a PBR and stator
Man I hope you get it off the hill soon. Have you tried any sort of tss delete, voltage regulator? I’m just spitballing. Mine has me stumped as well
Just paid the piper and got sled flown off. Fixed the thing in 10 minutes.
Hooked up to Cando and 4 codes of silencer pipe sensor came up.
Tried starting it and would start and die. Installed new sensor , all better but my pocket book.
Also I have the Ezlynk. Hooked it up and no codes showed up.
This is not the first time this has happened with the Ezlynk.
Next a call to their support line.
Great I just ordered ez lynk for that exact reason lol
Glad you got it figured out
I have Cando pro
Also opened up a case with EZ LYNK on why it would not pick up the codes. No response yet.
I'm thinking that if the check engine light does not come on EZ LYNK wont pick up the code.
Cando pro is more like digital wrench where it will pick up codes in the ecu before they trigger a check engine light.
