2022 Khaos 155" suspension setup
Steep&DeepRider
Just got a 155 so I need advice on where to set up the suspension. Where is a good spot to start at? Anybody have any ideas on how many clicks from soft etc etc???
Sent from my SM-S906U using Tapatalk
Start in the middle of the clickers . Adjust front skid shock stiffer for a lighter front end feel or vise versa. You will trench more the stiffer your front shock is but will be a wheelie machine . Softening the rear track shock will also effect ski pressure. Turcotte has a good video on where to start and fine tune for riding preferences
I think I started in the middle with mine. Then tried this set up:
I adjusted from there and still play with it depending on the trail conditions. My front skis were set narrow so I ended up adding more preload to the springs to keep them from diving hard when on edge.
That table came from the SnowTech winter of testing on the Khaos and that is what they settled on. It may have seen more flatlander rides than standard mountain rides, but might be a place to start.
