So how does one get his hands on some lighter weights for this clutch? I would pay to overnight a set for my 10,000-13,000 ft demo ride this weekend. Might be a waste of time with too heavy of weights...
When you replaced the weights in the Team, did you reverse the clutch bolts to match the past AC clutch?After riding the new 2016 M8, had to pull it apart to see the Team clutches. After 40 miles of riding it was still only pulling 7450 rpm on a hard pack hill at 9500 feet.
Clutch came off and apart just like the cat clutch. The spring and weights are different.
Clutches weigh exactly the same, 12.4lbs. With the addition of the steel spider in the Team clutch I was hoping they would still weigh the same. The steel ring is still on the back.
Cat 65g weight left, Team 70g on the right
so is it worth buying the team of go with a 911 cover on my 14 ? was thinking real hard about buying the secondary but not sure about primary
have a 16 in the shop anybody take the secondary apart yet?
Just put my first ride in on my 16 m8ltd. Awesome!! Clutching was smooth and power was spot on. Then things got interesting. Noisy. A rotating kinda scraping noise. Seemed like it was at low speed but not sure if i just couldnt hear it under throttle. Not very educated ar all about clutching.. Any ideas? I will try to post a little vid where you can hear the noise. Thanks
