C
Carlos Randolph
Just cleaned the power valves, and took a peek down into the bore, and compression check (1700 trouble free miles). The mag side piston has one hair line scuff line below the bottom ring. Rings look like new, no flake. Top of piston has a nice brown color. PTO piston shows no scuff at all, rings and piston top same as mag. 5 pulls at WOT 120psi on both sides on a warm, not hot motor. Valves had about 6-700miles on them, from last cleaning, and were pretty gummy/coked. Had been running VES oil, or AMSOIL. Plugs
were a little dark, and ill swap them out. Ran the 9eix with great results, seem to get less build up on them IMHO.
Have run the factory/dealer oil setting just In case for warranty, and premix 4oz of oil in every tank. The factory oil setting I at 68-70:1 by my rough figures.
I also with out fail, let the sled warm to 100deg or better, then go. Have ridden it hard, and at times have almost expected something to break/burn down, as that has been my past result. Shame that I am conditioned to that mentality$$$.
Based on my findings, I am going to keep adding the oil. So far so good
I am considering doing the BMP airbox mod, for the claimed 3-4 free HP. Any one else try this? If so did you go all in and get the PC 5 and add some fuel?
I am a Doo convert, after the 08XP debacle. Now on my second pro 800.....pull the rope and ride, is way better than....I hope it skidon't break again. They are a nice piece.
