2010 RMK 600 bog
retiredpop
1,350
295
83
Calgary
I have a bog after the sled has been ridden for quite a few miles so it is fully warmed up and then shut off for a while. Usually temperature is around 105 or so after the short break. Upon restart the sled bogs at low throttle for a while until temperature gets back to 125. It's almost like the low speed injectors don't flow enough although on the first cold start of the day it does not do this even if the temperature is not fully up to 125. If I hit the throttle it picks up like normal. Any ideas?
retiredpop
1,350
295
83
Calgary
I found one of the bullet connectors for the pipe temperature sensor was not fully pushed together. I'm not sure if that was the cause but will know next time out.
