L
lacesout
I have a 2015 ST kit coming for my 2010 KTM 450SXF. I have a list of questions. Any help would be appreciated!
-It has a carb so jetting is obvious. JD jetting kit is best?
-I heard I should run a 50/50 mixture of race fuel and premium gasoline so the carb doesnt freeze up?
-Do they make a bolt on carb heater for the KTM yet? Does wrapping the carb with neoprene help it not freeze up as bad?
-Are oversized foot pegs necessary? What ones are the best?
-Do i need a sand cover for the air filter? Is that all that needs to be done with the intake?
-I have a trail tech stator and fly wheel but am affraid to install it. I heard it kills the high end badly. The extra 8oz of rotating weight takes away HP?
-Am i able to run heated grips without doing the stator and flywheel upgrade?
-Is an oversized rad necessary?
-Are rad protectors necessary?
-Does wrapping the exhaust pipe do anything?
-Rekluse clutch necessary?
-Plastic skid plate is better than alum one ive heard?
Sorry for the big list of questions. Just trying to figure out exactly what i need before the snow comes! Thanks for any input guys!
