Nope no black marks when I checked the last time yes belt was cleaned.
OK guys was out riding yesterday in 2 feet of powder stopped could of times and noticed that both clutches are burning hot and I can tell this belt if getting ready to blow. Some of the cord is missing I also noticed I am over reving by like 400 rpms and guess thats why I am heating the belts so much due to slipping. Anyways I am waiting for the alignment bar to come in and going to order some CPC adjustable weights. I also already have vent kits in. What else should I look for?
Trust me on this. You need to move your secondary in. IF you take that belt off you will see the side of the belt that is facing away from the motor it s starting to cup from slipping in the secondary under load.
As the belt wears guys will be the first to tighten up the belt but never give moving the secondary in a thought. See as the belt thins the two fixed sheaves need to move closer together to keep the same pinch on the belt in the same shift ratio.
Pull the secondary off and pull one .060 shim out to start then keep pulling .030 out till the heat is gone.
NOW if you take off the secondary and find there is only one shim in there you have one of those sleds that needs the motor mount shim kit. You will have to move the motor over to get more belt pinch to keep the belts from blowing.
You have to trust me on this.
Don.
Are you talking about the shims that are behind the bolt the ones to adjust the deflection?
also got an email back from CPC.
The 2009 M1000 is the hardest sled on belts in the world. The fix is to put a new engine motor mount on the is speciallly built ($185) and to install a after market additional motor mount ($285). Then at that point, I would suggest some CPC adjustable cam arms. This is the minimum recommendation. Later you could install our diamond drive conversion kit for the secondary driven clutch ($299). Thanks Dale
Just blows brand new sled and havd to worry about this stuff. Was hoping for once wouldnt have to worry about having problems.
Hey guys just blew a belt today riding around here at home I have read a few threads and was wondering what should I check for on the sled?
you better plan on replacing alot of belts on the 1000 300 miles seems to be about average unless you just putt around. thats just the price you pay for horse power and tourq.
Where did you get the push arm and mounts from that are in the pics nice install???
RockyMtn.Kris did you drill a new hole for the mag mount or use the one that was already there?
Do you have to change much in the clutching to run the 46 belt from the 60 belt.
