D
deaner
beautiful sled, but the one thing that blows me away is that no one else out there except boondocker uses intercoolers anymore, the tech from bd told me if i was running 10psi or more the charge temps get pretty hot and it just gets that much closer to deto!
the use of larger turbos help move more air and dont have to work so hard like the smaller turbos and that helps makes charge temps lower ! bigger cc engines have the bottom end the old M7's didnt have so spool up isnt much of a problem off the bottom anymore so now u can use larger turbos ! ! plus if u run an intercooler with out a hi volume of air moving threw it your charge temps will be higher than if u didnt have the intercooler ! the intercooler will hold the heat in like an oven without the air movement ! this is why the turbo gods dont use them! So im told !
mike![]()
So, can I remove my intercooler on my 08 m1000 with a boondocker turbo? Can I just stick a charge tube in there with my ADA sensor and blow off valve and call it good, or will it change my numbers by quite a bit??
Sorry to hijack your thread isattv. Beautiful sled!!
![Beer :beer; :beer;](https://www.snowest.com/forum/images/smilies/beer.gif)
