G
G_dub
It's a Model VFS8526TA2 Drive in and Drive out V-nose trailer. It's 26'1" over all length. 25'1' over all inside length including V-nose and 21'1" on the square.2 5/16 ball 2 3500LB Axles with brakes. And 2 Fuel door's The trailer is set up for Snow Mobiles. It was bought 7-18-09 at a local dealer it still has the 3 year warranty from Pace American from date of sale. The stuff I have done is listed below in addition some specs from the Pace American website. This trailer is great for storage and hauling all types of thing's we have moved stuff all over the country in it since it was purchased in addition to hauling my sleds up to the hill's it will fit 4 Long track sleds I have had 2 163IN tracked sleds nose to tail in it and they fit just fine I have hauled 5 sleds total in it 3 162/3's and a 159 and a 153 all fit perfect it was tight but they fit. Trailer has about 6500 Miles on it since I bought it. Asking $7500.00 Cant take much less than that. Maybe interested in a 2 place drive on drive off if the trade is priced right! I can deliver. And I know I will forget some stuff that's been done. It's a nice trailer add heat which was a plan and you have the ultimate set up!
Mod's I have done:
* 4 Gallon's of Rustoleum brand no slip floor coating. on both door's and floor.
* All wall's of trailer painted white and man door.
* All lower half's of the wall's have .030IN Aluminum to protect walls from ski's and loop's
* Both Ramp's and floor has plastic truck bedliner put down for ski guides
* Both Ramp's have either old hyfax or old drive belt's so the track can get traction
* 3 Custom made helmet racks out of .030IN Aluminum dimple died for strength and look's and allows helmet's and boots to air dry.
* 1 Custom made aluminum rack for fuel or oil storage
* 1 Custom made rack with dividers and shelf for small part storage
* 2 LED Light's at rear to add a little light when loading in the dark
* Full size spare tire and wheel
* All kinds of Hangers for Coats, Tie down strap's, brooms, shovels, backpacks.
Only bad thing wrong with the trailer is on the Right (passenger side) out side of the trailer is some damage when trailer slid into another and wrinkled the lower trim and a little of the side. No Holes didn't damage the trailer structure or any thing like that. It's noticeable but doesnt hurt the integrity of the trailer. Also some light scratches from tree's once again scratches don't go down to bare aluminum just surface scratches.
Pace American gives you quality standard features that are solid value from design through the manufacturing process. Some equipment that comes standard on Pace models is optional on other brands. At the end of the day, Pace standards equal maximum value.
* White in Color
* Fully-Protected 12v Wiring Routed thru A-Frame Tube & Underfloor PVC Tubing on Tandem Axle Models
* Patented Dust-Proof Sidewall Design for Strength and Cleanliness
* Dexter Torflex Independent Torsion Suspension (ITS) Axles
* E-Z Lube Hubs
* Trailer Rated Radial Tires
* Modular Style Steel Wheels with E-Coat Primer & Powdercoat Finish
* Aerodynamic V-Nose Front Design
* .030 Aluminum Exterior with 16" On-Center Wall Posts
* 8" Steel I-Beam Standard on 30TA3 & Larger
* Frames are Phosphate Power Washed and All Exposed Metal is Painted with Premium Quality Paint
* 16" On-Center Crossmembers on TA3 Models and Larger
* Recessed Rear Ramp Door w/Spring Assist and Flap 5500# Capacity on Auto Models
* Beavertail on Auto Models
* 3/4" Plywood Floor
* 3/8" Plywood Interior Walls
* Cast Aluminum Door Hold Back
Thank's for looking!!! Contact getitbilly@gmail.com for additional questions.
Thanks,
Greg
Mod's I have done:
* White in Color
* E-Z Lube Hubs
Thanks,
Greg
