2 black wires
There's 2 brownish black wires looks like a bolt goes through it to the bumper bolts? Not sure can't remember taking them off they come off the wiring harness. Do they sit loose or do they connect as ground wires?
Yes you have those chassis grounds mounted in the right spot. Having them disconnected may well cause issues revving up. They really should be connected to the chassis.
Ok awesome thank you. Thought I had them right. Got it all together and now got fuel line pin hole lol. Of course right. Also my low beam don't work but high does. Have any idea whats going on there?
Yeah, pin hole in fuel line is no good, fix that, lol.
For your lights, if high beam works but not low, the problem is likely somewhere between the switch and the bulbs. I'd check the bulbs first, that's easiest. Though if both left and right low beam went out at same time, it's likely not the bulbs. I'd check for voltage with a multi-meter at the bulb connectors (low beam is dark-green/yellow wire on my 2012). Try cleaning the switch up good, trace the wires from switch to bulbs looking for shorts. Start with that and see what you find.
Haha ya definitely getting it fixed. Found deal on ebay from guy I know fuel rail and throttle body and lines for 57 bucks. Polaris wanted 201 just for return line lol. And ok ill do that thank you ya both just go out at same time but both high beams work good. Think lows were coming on before but sometimes flicker and shut off
