2.5 camo extreme on 09 d8
A
aus091
how do i go about getting the drive shaft out from underneath my sled to put the new track in, is there any way to do this without draining the chain case and taking that all apart? Anything will help thanks.
you have to drain the case in order to pull the cover..then you can loosen the tensioner, and remove the bolt holding the lower gear on and remove the lower gear and spacer..then the shaft can be pulled....
alrighty, what type of oil should i use in the chain case when i go to fill it back up?
i got it in without too much trouble, everything looks good and i am very impressed with the track itself, ill put up pictures if anyone is interested
